Hi
Have a 1995 RV down here in NZ
Experience pressurisation of the coolant system when I'm towing a load up hill. The water is pushed out of the radiator cap. When I refill the radiator it's fine. It only seems to do this when I'm travelling up a hil with a loadl. Outside of this I never have problems with overheating.
The radiator and cap were replaced 2 years ago. Also the thermostat was also changed.
Investigation on the web offers up the following:
Replace cap - check it's the correct rated cap for engine
Replace thermostat
Pressure testing coolant system check for leaks etc
Pressure test head gasket and intake manifold
Any suggestions/thoughts
Many thanks
Brian
Replace thermostat
Many thanks
Brian
