Cruise control
Hi,
This is aimed at Julian but anyone with the parts system on their
PC may be able to help.
I am trying to take off the cruise control restriction that my
cruiser has (70 MPH). I need to find the CC ECU. Julian told me it was
in the centre console and I have just taken the cover off and it was
not there. If it is under the cubby box bit I haven't got there yet.
Julian,
If you could check this for me I would appreciate it.
One fine day I will ask you to get the parts system working
on my PC, I never had any luck with it.
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
Hi Clive,
I have seen it on some cars under the console over the gearbox tunnel,
right beside the shifter (to the left once you have removed the panel.
However the diagram for your model on the EPC (still have it on file)
is ambiguous, it could well be behind the dash in the centre.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
Thanks Julian, I will investigate a bit further.
Clive Marks
