Lorin
- Mar 28, 2010
After much deliberation (between a CTEK and a Sterling) I have just taken delivery of a CTEK D250S Dual alternator to battery charger for my auxillary batteries. The reasons I opted for the CTEK over a Sterling in the end were: (1) the CTEK is also a solar regulator (built in) and will automatically switch between alternator and solar power to keep the auxillary batteries topped up; (2) the CTEK is IP65 rated which can only be a good thing; and (3) the CTEK is a physically smaller unit. Like the Sterling the CTEK uses a staged charging pattern that de-sulphates the batteries and ensures that they are fully charged. It also monitors the state of the batteries to be charged and adapts the charging pattern accordingly.
However, having now got it and read the instructions there appear to be a couple of potential issues I want to check out before I install it. And I am bl**dy confused how/why an alternator doesn't cook the starters (despite reading everything google pulled up in the last 2 hours!)
Firstly, it appears the CTEK draws a current as soon as the engine is started (max output is 20amps so max draw must be just above that). It has no capability to monitor the starter batteries nor does it wait for a set time before drawing a current. Given this, am I right in thinking that there is the potential risk of the starter batteries not being sufficiently restored between stops? For example, when you are doing a a fair bit of short duration stop-start driving and the auxillary batteries are low thereby drawing the full 20amps. If this is correct, could I offset the draw of the charger by installing a bigger alternator, say a 100amp rather than the standard (I think) 80amp?
This then led to my confusion re alternators. From what I gather, an alternator can push out a max current of say 80 amps but this is regulated according to what is required (i.e., the alternator ups output in line with demand such as when turning on all the lights etc). If your starter batteries are fully charged with the engine off and you then start the engine, the alternator will replace the lost charge. And herein lies my confusion. From what I have read, the state of charge of a battery determines how much current it will draw in order to recharge itself. The alternator then regulates the current via the 'diodes' accordingly - to how much the battery will accept. However, an alternator cannot produce no current, or can it? So why doesn't it cook the batteries once they are charged?
Also, my understanding of charging batteries is that there is a max charging current above which it is damaging to the batteries and that this differs according to the state of charge. For example, when really low they can accept a high current but when nearly full they only need a low current and somewhere or other I stumpled across an equation that basically said the max current it is safe to put into a battery is approx one fifth of is capacity (for standard lead-acid). Is this correct?
If the above is correct and I have 250ah of auxillary capacity, am I right in thinking the max 20amp output of the CTEK is not really sufficient to charge the batteries - in an optimum sense? Would I be better off with the Sterling that has a max 50amp output? Related to this, whilst I cannot find confirmation, I am assuming that the 'intelligent' chargers such as the CTEK and the Sterling are able to determine the capacity of the batteries to be charged and can therefore adjust the max current they put into them rather than just bunging all 20 or 50 amps in?
I accept there is a real possibility I am just being thick and have got it all wrong, which actually I kinda hope is right. But if not, why can't one company just produce a charger that does what is needed instead of them all producing chargers that do different bits but not the whole lot.
Apologies for the essay
Any help/advice greatly appreciated.
