- Mar 1, 2010
You have to have water in the diesel for this to start. Not the water naturally dissolved in all diesel but separate water which has an interface with the diesel. If the water is not pure, which is likely and contaminated with mould, the mould grows in the water taking vital nutrients from the diesel. A lot of mould means it can clog pick up pipe filters etc. If you use diesel from a forecourt you won't get the mould 99.9%. If diesel is from another source you must use a filter funnel to stop any water or mould etc etc passing in to your tank. Filter funnels were designed for this purpose and are a common sight on farms and building sites.
It's easy for motorists and boaters to just use cans for conveying diesel and assume everything is OK.
