- Dec 5, 2012
Hi everyone.
I could really do with your help... The bottom end of the engine I just fitted went to VM Specialists and had new piston rings, 1 new liner and new seals fitted. They also cleaned it all up, checked the timing gears and oil pump.
It came back to me and I swapped all ancillaries including injector pump before getting it running.
It ran 3 times
1st for 3-4 minutes a bit rough. alternator belt was too loose and screaming. shut it down, tightened belt. general smokiness all around vehicle.
2nd for about 20 minutes. Bled cooling system. ran more smoothly but guessed the injector pump timing could be tweaked. fiddling with cold start advance had no effect on running. At first I thought it was blowing smoke out of the exhaust manifold but on further inspection smoking quite heavily from crank breather ports on nos 2 & 3 rocker boxes. I hadnt yet fitted the hoses that carry the gases down under the engine.
3rd for about 5 minutes after re-torquing head bolts and fitting hoses to crank breathers. no smoke in engine compartment at all. blowing smoke from crank breather hose. blew nan injector out and that was that.
The question I have is what could be causing the smoke from crank case?
There was "steam train" chuffing from oil filler cap when removed and dipstick hole.
I need to make a decision about whether I invest in new or recon cylinder head(s) if the bottom end is worth saving, or whether I bodge a repair to get me back on the road until I can fit a 2H.
I mean no disrespect whatsoever to George... he has been brilliant. Friendly, and extremely helpful... but is it possible that something has failed?
I may well be wrong (I often am) but I thought that the only way the crank case could become pressurised and blow smoke was if gasses were leaking past piston rings.
What should I do?
To be honest, the sooner I get a 3B or 2H in this thing the better.
Thanks in advance for your help.
OD
It ran 3 times
What should I do?
OD
