Diesel engines at altitude - 1HZ
Bmonck
Hi
I spent a lot of time last year above 8,000 feet and a fair amount above 10,000:feet. My truck has the naturally aspirated 1HZ engine. It really struggled. Obviously less oxygen at altitude and partial combustion produces much less power, black smoke and a very noisy and unhappy sounding engine. I think a rule of Thumb is that you lose about 3% of power from every 1,000 feet above sea level. So for 10,000:feet that’s 30%!!
So the question is what can you do about it. And especially anything you can do while you are on the road. Are there timing or fuel delivery/mix adjustments that can be made?
I know fitting a turbo would help a bit but don’t want to go that route.
Any suggestions or ideas welcome.
My 105 has the optional altitude compensation device fitted to the fuel pump. Not exactly genned up in it yet but perhaps it may be worth looking into?
I would expect an inter cooler to help
Forgive my ignorance but how does that help? Is this just cooler air is more dense?
Air at altitude is pretty cool anyway, certainly compared to the lowlands, so not sure an inter cooler makes a big difference does it!
Did you fit or was it a post factory mod?
Where can you get them?
My thinking is simply that your filter housing and pipe work will all be warm from engine heat so a bonnet scoop and top mount might just make the most of what little oxygen there is .
Pointless at lower altitudes im sure . Just a theory .
How come your not keen to go the turbo route?
I can't see how the altitude compensation would do much apart from reduce the fuel in relation to the air density. Cant get past the physics of less air = less to combine with fuel and burn.
I looked into getting one of these for my 1HZ - It seems you can't buy the altitude compensator separately and retro fit it, you need to buy a whole new fuel pump assembly (although I may be wrong)
I know your struggles @Bmonck . Honestly I would say the best thing to do, especially because you're already on the road, is to shift down to a lower gear and enjoy the slower pace of life.
Partly just the cost. The engine is brilliant except at altitude. Not fast but never stops
Agreed that was my only option. But I wasn’t really after speed but frankly was also a little embarrassed in a pristine environment to be belching so much black smoke. Engine was clattering too. Anyway maybe there is nothing practical to do.
In general I don’t spend much time at those altitudes so I can live with it.
