driver window switch
jj01
australia
anyone had any similar experience window switch for driver side does not work however all other windows are fine on the master switch..
ordered new master window switch albeit the cheaper option after market version plugged in same issue all windows work except for driver window
I had similar problems with my '90'. It turned out to be a fractured wire where the wiring exits the door - it is constantly flexed as the door opens.
A bit of re-wiring cured it (until the next time).
Bob.
