Steveindar
- Nov 17, 2014
Morning All, a week ago Sunday we had a fire when wiring loom caught alight at front left where the loom passes behind the headlight and in front of the battery. Didn't think to take a pic of the fire, too busy extinguishing! Anyway I stripped out everything in the way then slowly tried to trace all wires by colour in order to replace the damaged sections. Inevitably there were some that had burnt all the colour coded insulation off creating a real mess.
I managed to get the main supply wiring reinstated so now the car starts and runs. following colour codes I also got the lights and indicators up and running. I am now left with a few odd wires that don't seem to have a home and don't match ends and there are a few weird issues happening. Dash lights not coming on, Headlights don't switch off when ignition off. Lights coming on when dark and ignition off and key removed! It has an auto position on the stalk and a light sensor I assume, where would that be?
What I desperately need is a specific wiring diagram for the under bonnet fuse box loom. It covers all the front end lights etc. I am sure that I can trace all issues with that.
Car is 1HZ HDJ81
Steve
Car is 1HZ HDJ81
Steve
