And there was great rejoicing…Success! New splitter applied (after leaving the old one on over night and under pressure) and a couple of sharp taps and "bang", taper shot out like a bullet. Thanks for the advice all.
And if one wants to reuse the part, ie the steering arm…?Heat. Its that simple. If you are not intending to re-use the part the get it red hot if possible. Honestly and I would only use the gas torch not the Oxy anyhow. If you jack up the axle and then lower it down onto a heavy piece of steel so that the Ball joint Pin is taking all the weight, then strike the hub downwards. If you might need another solid bar/tube to hit in case the head of the lump hammer doesn't fit, shouldn't take more than 10min if your kettle is 3kw
Almost as good a feeling as winning the World Cup.
Oh come on dave!You remember that Frank?
I have been invited to go and watch the match at a friends this pm, unfortunately I have painted a door and need to watch it dry.
Dave
Right, daves at the door and football's just about to start..
