Got myself onto the Communication Eleven 4x4CB web site & using the clubs discount code ordered myself the following items
Intek M-760 CB (decided upon this rig as I wanted something that I could din mount with a forward facing speaker & scan facility).
DIN mounting kit.
3' Thunderpole Orbitor twig - a Springer by another name (no matter how I looked @ all the different twigs I just kept coming back to this one).
Stick on Mic holder, two male coax connectors & one double female coax joiner/coupler.
I didn't order any coax a SWR meter or a twig mount as I had enough bits & bobs knocking around from previous CB ownership to cover this
The very next day I got a phone call from Jim @ Communication Eleven 4x4CB to say that he had sold the last M-760 rig that he had in stock just before my order was made & would not be getting any more in this side of Christmas
We had a quick chat about why I wanted this rig & he then offered up the Albrecht AE 6490 as an alternative
It's not yet listed on his site & is £20 dearer than the Intek M-760 that I had originally ordered but is a better spec rig that comes with its own DIN mounting kit so that made it only £5 dearer than the Intek option for me as I could loose the TTi DIN mount that I had also ordered @ £15. Jim then went on to say that he would swallow the extra fiver himself if I decided to go for the Albrecht rig in exchange for sending him some photos of it once I'd fitted it
So after he emailed me some photos of it I agreed to change the rig from the Intek to the Albrecht (apparently made in the same factory as they make the Midland sets)
I must just say @ this point that Jim came across as a very honest & helpful chap - Thank you Jim
Here's a couple of the photos of the Albrecht AE 6490 that Jim emailed to me
Everything that I ordered came in the post the very next day
So I got on with fitting it all
All went well I've fed the rig from off of the ciggie lighter power supply & I found that I didn't require the DIN fitting kit to mount the rig in Fiery
I did however need to re-drill the standard fit double DIN Toyota mounting plates so I could pick up the two standard M6 holes either side of the rig. In place of the thumb screw fixings that came with the rig I used a couple of socket dome heads I had knocking around
The only other thing I had to do was remove a bit of rubber trim from around the outside edge of the rig in order to get it to fit nicely (this will easily go back on should I decide to remove the rig for resale)
I don't no if the same is true for other rigs but I didn't have any use for the DIN fitting kit that came with the Albrecht as the rig is the same width as a standard radio/CD player
I'm not sure if this would have been the same for the Intek but if so then the DIN fitting kit that I originally ordered would have been of no use, so worth checking before buying
All fitted
What do we all think then
I do have some concerns with regards to the SWRing
I drove out into the middle of nowhere to set up the SWR away from trees, buildings & overhead power lines
Right here in fact
Set the rig to CH20 keyed the Mic to set the SWR but even with the CAL knob wound fully clockwise I couldn't get the needle right over onto the set position so the rig with no aerial adjustment shows a SWR of less than 1
Have I missed something surely without getting the needle to sit on the set position my true reading for SWR must be higher
Some advice on this matter would be appreciated
DIN mounting kit.
All fitted
Right here in fact
