FOR SALE UZJ100 1998 Toyota LandCruiser
Mack10
united_states
This an't a garage king, but shows and runs well.
This is not a scam of any kind, I live here in Puerto Vallarta Mexico.
For sale is my beloved Land Cruiser, don't want to sell but have personal priorities that have come up.
Has USA Texas tags.
Specs:
This UZ100 1998 Toyota Land Cruiser
Engine 4.7L V8 2UZFE DHC built in Japan.
Automatic
186K miles
Options:
Fully loaded with the locking rear (7 pin mod) differential, power windows/locks/sunroof/seats/cd tape/AC.
Added a switch to turn on/off the day-time-running-lights.
Services/new parts:
All fluids were changed again short time ago (all synthetic fluids) at GoodYear. The radiator/front DIFF/rear DIFF/transfer case/engine oil/brake fluid/power steering fluid/air filter/fuel filter, and fuel injector flush.
The entire air-conditioning system was serviced with a new evaporator, expansion valve, and condenser filter sock. Had the AC compressor checked out for any future issues.
New plugs and coil packs.
The timing belt was inspected and passed the visual feel test a Toyota tech and myself. So, no cracking or fraying.
The starter has been reconditioned.
The timing belt was serviced around 125K miles, I will include with the sale of this LC a full timing belt (timing belt/water pump/crank seal/cam seals/gaskets/hydraulic tensioner/idler bearing etc) service kit.
Comes with $3000 US worth of extra parts like fuel pump ecu/alarm ecu/door lock ecu/main engine controller ecu/dash instruments control ecu/timing belt kit with water pump/crank seal/cam seals/gaskets/fan clutch/hydraulic tensioner/idler bearing/fan bracket etc,and some other useful parts.
New tires with armor in side wall and in the treads/new lower/and upper ball joints/new polyurethane compound power steering rack bushings
New front CV drive axles with polyurethane compound boots.
New front/rear sway bar bushings.
Firestone rear air-spring/bag system
All new door (5) lock motors.
Comes with a four bike, Hitch-mount bike rack.
All the emissions systems are intact and are working.
Body:
Looks great, new paint on entire truck. Some minor work is on going.
Never any frame or core support damage in its life, all body panels/glass (with exception of the front windshield) are original to the truck from factory.
Interior: On a scale of 1 to 10 I would give it a 7 on condition.
All dash gauges are in working order and their ARE NO check engine/brake/ABS lights on.
The seats are NOT perfect but look good on a fast look-in, the seats have some cracking, the carpet is good shape with not rips.
Come withe the removable third row seats, they are in great shape.
The front passenger and drivers seats bottoms have been recovered.
The door audio speakers have been recovered.
New audio speaker in the front/Alpine and rear/MTX.
All the door panels have restored and they look great.
Has all the cup holders in working order.
All the power ports covers are their and are working as well as the cigar lighter.
All the power control switches such as power windows/locks/AC/heated seats ECT are in working order.
The only thing not working on this truck are the power mirrors, I have extensively looked into this as well as the Toyota dealer.
The windshield has a crack from the top to the bottom.
It's in great solid running/driving condition. Drives very smooth almost like when it was new even with the more aggressive tires.
The power steering rack has the normal seepage. Never noticed drop in the level.
The crank seal is seeping oil (says the Toyota tech) never low on oil nor does it burn oil.
322 148 0893 Located in Puerto Vallarta Mexico
U.S.A. # 571 933 7356
$7600 OBO
Nice truck. Super location for pics too - they look excellent. Good luck. The truck itself would probably be around £6000 just on its own here...
Thanks, I'm curious how much is £6000 to US $ dollars?
£6000 = $9811:26 for future use you can get currency conversions at I've found that very useful on occasions.
Wow, I would very much like to get that $9811.26 figure for my beloved LC. I think the seats should be in better shape for this figure and or the timing belt service would need to be completed.
I would like to get around the $7600 range.
Keep in mind that this LC comes with the timing belt parts kit as well as new replacement the take-off parts like fan bracket/idler and pulley/clutch fan/belt tensioner. And a set of new inner and outer CV axle boots.
