SOLD: For Sale: 2001 1HDFTE Auto (161k Miles)
Howmanygoes
Its a hard decision but life changes mean I need to sell "Thomas", and yes I know I may regret it in a year or so, but we will be funding a new build, that we hope will gives us the adventures we seek.
Its listed on EBay - but would rather it went to a forum member so i can keep up with his travels. £12.5k or £15k with your choice from the extras
A Toyota Landcruiser Amazon 4.2D Auto 1HDFTE, Model year 2001 - 4 Speed Auto (Torque converter addressed)
Thomas came to us in December 2018 as a standard vehicle. It has since been built up for self supported travel. As a family we have loved the adventures this truck has given us, having travelled to a number of European countries, recently returning from a 1400mile trip, however we realised as the family has grown ,we now need a larger vehicle and cant justify this as a once a year play toy, so we hope it finds a new loving owner. We have added 17k miles in the 6 years we have had it. Its a 23 year old truck that's been used on great adventures, so its not perfect. There's over £10k of included modifications.
As a complete package Thomas is ready to go, add fuel water and food and you can be off grid for 10days as an induvial.
Road tax : 189.75 for 6 months
I have 2 keys and the V5.
Recent straight through MOT (April 2024) no advisories
Initially a health inspection was undertaken by Overland Cruisers and a period of baselining maintenance was undertaken before modifications started. Lots of work has since been undertaken (key points listed below) as well as frequent Oil changes (6k Miles) 2 box files of paperwork and instructions will be supplied
Torque convertor replacement 2019.
Timing Belt 2020
Alternator and all 3 belts (May '24)
All 4 Wheel Bearings (June '22 - Overland Cruisers)
Front Diff rebuild (June '22 - Overland Cruisers)
Body work, Windscreen removed, rust cut out and replaced & Rust cut out and new metal fitted to rear aches (Jan '22)
New steering rack, upper wishbones, ball joints (Dec '22)
UJs replaced and props balanced.
Roll over cut out IP connection replaced
Modifications
5x BF Goodrich A/T 285/65/r16 - all with good tread
Front Runner Slimline2 Roof rack
Ironman foam cell pro shocks, torsion Bars and heavy duty rear springs. Fitted December '22) 2inch lift with AHC components removed.
Fabryka4x4 Rear bar with wheel and jerry can holders
The Cruiser Company (Australian import) twin gull wing door kit
Hurrican Fabrication (Australian import) tailgate storage modification
Terrafirma 12500lbs synthetic winch
AFSIR Front skid plate.
Onboard ARB air compressor
Diff and gearbox breathers extension
Snorkel
8 gang switch controller serving, all additional lights, tent, winch.
Rigid 360 Spots
Rigid Cubes (scene lighting)
Strands 50' Single + Amber light bar (not a cheap Chinese bar)
Rear spots
Escape gear (South African import) Seat covers, arm rest and centre console.
Ctek 250sa Dc to DC charger
Victron Mppt 100/30 solar charger
Victron 800w inverter
Victron BMV 712 - smart shunt
130 AGM battery
50L Frontrunner water tank
Trail king water pump
2 Stage water filtration (currently 5m and 0.5m filters fitted)
Tankless Gas hot water system and shower (uses water through filtered tank system)
Shower cube curtain (Direct 4x4)
Drawer and fridge slide build
240v power and usb power outlets
Bison gear recover track holder
Recovery tracks
Spare wheel trash bag.
GPS Tracking system with automatic immobilisation
Android 10inch head unit with Rear camera and DAB+
Midland CB radio and High power antenna.
Phillips LED head lamp conversion (and normal bulbs included for MOT)
LED Side light bulbs
2 recent new Bosch Batteries.
Spares Included in the sale
A box of travelling spares, belts, bearings, UJs, lubes, filters (Fuel and Oil)
Genuine injector lines (full set of 6)
Rocker cover gasket.
Original rear windows (if you want to remove the gullwing)
Original rear bumper
3rd row seats and all plastic and seatbelts to return to a 7 seater)
Pre heater cable if you want to reinstall.
Expedition Extras - Not included in sale but available by negotiation.
Bundutop Bunduking Roof Tent, and add a room awning
Ostrichwing 270 degree awning and side panels with under canopy lighting
EziAwn Table and mount rack mount
315w solar panel
Diesel Heater mounted in a box
52L compressor fridge (mains or 12v)
Bad points
Front sway bar bushes need replacing (Genuine bushes and new brackets are included in the sale)
Rear diff lock. The electrics and switches are fine, needs a new actuator, not been a priority for us.
Slight leak from rocker cover (hence the new gasket which I was going to do at the same time as the fuel lines, inlet clean and clearances as part of that service.)
Running boards removed in readiness for sliders
There is some surface rust underneath, to be expected. It was on or list of preventive maintenance to do. Nothing structural. worst bit is on the fuel tank cover plate, but lined up a fibre replacement through the forum.
Bodywork,
We have done some laning and mild off road in the truck, so there are pinstripes to the bodywork and small dent to the offside rear.
There is a small rust blister on the offside front wing (about the size of a 10p piece).
The rear tailgate has a dent on the internal top, which was there when we bought it. This doesn't affect security or water tightness.
Bank transfer (proof of fund receipt) or Cash on collection only. No PayPal.
Private sale no warranty or guarantee given.
No returns
Unknown currently. Likely to be a compromise, comfort, size, practicality, reliability and capability. Isn't it always.
I don't have the space or equipment for a MOG or Lorry based platform. We shall see.
I’ve gone through the same debate over and over. The LC is still one of the best compromises if you’re able to fit a pop top (alucab equivalent) it’s a game changer
