Front drive shaft nut size...
Danny b
Does anyone know the correct socket size required for the front driveshaft/hub?
I am not home so unable to measure and I know I borrowed a socket last time so want to buy one after work.
Thanks Danny
35mm i had to grind the bevel off my impact socket to get the bugger undone this morning .
If you can borrow one from work I've removed others before without grinding but a breaker bar direct to socket at an angle defeated me , i've lost my extension bar and i don't have an impact gun .
I think i got my 35mm from Halfords .
Just found one at work I can use. Will give it a go tonight. It's been apart before so hopefully no major surprises.
I have it down as 34mm? lets us know if its 35mm
I have an unused 34mm as well which i must assume was bought for the hub nut but doesn't fit .
