To continue the debate
- Quoted from
the Dieselplace:
We all know that diesel fuel has more BTU's than Gasoline right...
#2 Diesel .......................... 139,000 BTU's
Gasoline............................ 125,000 BTU's
So this is why diesel does more work (TQ) and has better MPG numbers compared to there gasoline brothers...
Here is some more to think about for BIO fuels... Small reduction but not bad...
Ethanol ............................. 76,000 BTU's
B20................................... 138,000 BTU's
B100.................................. 130,000 BTU's
Now for you common 3 diesel additives...
Naptha............................... 15,000 BTU's
Mineral Spirits...................... 19,000 BTU's
Xylene............................... 18,000 BTU's
So this proves the MORE fuel additives you use the LESS amount of HP/TQ and MPG your going to get from your truck... All its doing is washing out the fuel...
So how about 2 cycle oil...
2 cycle oil (avg).................... 138,000 BTU's
So 2 cycle oil isn't going to reduce the BTU value of diesel fuel. So its still a excellent choice as a fuel additive so far...
There is no benefit to using a higher cetane number fuel than is specified by the engine's manufacturer.The ASTM Standard Specification for Diesel Fuel Oils (D-975) states, "The cetane number requirements depend on engine design, size, nature of speed and load variations, and on starting and atmospheric conditions. Increase in cetane number over values actually required does not materially improve engine performance. Accordingly, the cetane number specified should be as low as possible to insure maximum fuel availability." This quote underscores the importance of matching engine cetane requirements with fuel cetane number!!!
So adding cetane boosters are not going to improve the performance of the engine and/or fuel.
Cetane improvers modify combustion in the engine. They encourage early ignition of the fuel. They encourage premature combustion and excessive rate of pressure increase in the combustion cycle.
Look at the materials they use in most cetane boosters. Mineral Spirits, Xylene, and Naptha none of these chemicals are even close to the diesel fuel family. They also have very low flash points like gasoline! Every one of them are used for degreasing and cleaning solvents.
Cetane Number is a measure of the ignition quality of a diesel fuel. It is often mistaken as a measure of fuel quality. Cetane number is actually a measure of a fuel's ignition delay. This is the time period between the start of injection and start of combustion (ignition) of the fuel. In a particular diesel engine, higher cetane fuels will have shorter ignition delay periods than lower cetane fuels.
Cetane booster tend to advance the timing of ignition. Hence the ignition knock that you hear. The lower the cetane number the less ignition knock you'll hear. Also the flash point and the auto-ignition temps of the fuel is reduced greatly.
Cetane number should not be considered alone when evaluating diesel fuel quality. API gravity, BTU content, distillation range, sulfur content, stability and flash point are very important. In colder weather, cloud point and low temperature filter plugging point may be critical factors.
All of the cetane boosters on the market tend to reduce the BTU content of the fuel. Hence it reduces the MPG and the HP/TQ numbers. Sulfur content is been reduced national to 520 HFRR (<15 PPM Sulfur) which mean less lubricity of the fuel. Cetane boosters tend to de-stabilize the flash point. Go back to my Chemical definition page and look at the flash points of the different chemicals."
There's a lot more interesting reading, in amongst the trolling on that forum.
