Beaujangles7
- Jul 19, 2023
Hi all, following a recent service my Land Cruiser Colorado 2001 3.0D4D would start but the cut out and would be reluctant to restart. I researched around this and found that air was probably being drawn into the fuel system somehow. So I thought I'd buy a new fuel filter (even though what I had was new) and fit hoping to clear any opportunity for the air situation. Fitted with no trouble however the problem was still there. So I ordered a new primer pump from Roughtrax and tried to fit, but I couldn't remove the heater from the old unit so re-assembled and booked the car into a garage.
After that I had a bad fuel leak all over the road; when depressing the button on the pump I could see diesel squirting beneath the assembly. So I stripped it all down and re-assembled once again. Still had a leak. Stripped again, cleaned all surfaces and carefully re-assembled which improved the leak but it's still there.
Can someone let me know if this is probably caused by the 'o' ring at the bottom of the unit please?
