FW Oil on Injectors 1HD-T
Am giving the old truck a good once over- doing some preventative
maintenance before doing a 3 week expedition in May.
I'm sending the injectors off to be tested and spent some time on saturday
pulling them out. I found that a couple were covered in oil from the tip of
the injector nozzle all the way up the shaft of the injector past the
o-ring. number=A0 1 was quite oily, number 5 was dripping with oil. 2 and 4
were mostly clean and 3 and 6 were bone dry. Has anybody got any ideas for
possible problems? The turbo was certainly passing oil but that would surely
cover all the injectors in oil?
should I even worry about it?
Main reason for oevrhaul is that engine is underpowered and quiet
inefficient and with 3000miles (most of it offroad) coming up it would be
nice to ge tht engine in tip top condition!
James Pugh
Harlequin Valet Ltd.
195 Galmington Road
Taunton
Somerset
TA1 4SS
=A0
Tel:=A0=A0=A0=A0 01823 32 32 45
Fax:=A0=A0=A0 01823 32 39 42
=A0---------------------------------------------------------------------------
The information contained in this message is confidential and is intended
for the addressee only.=A0 If you have received this message in error or there
are any problems please notify the originator immediately.=A0 The unauthorised
use, disclosure, copying or alteration of this message is strictly
forbidden.=A0 This mail and any attachments have been scanned for viruses
prior to leaving the=A0 network. CRDN will not be liable for direct, special,
indirect or consequential damages arising from alteration of the contents of
this message by a third party or as a result of any virus being passed on.
Harlequin Valet reserves the right to monitor and record e-mail messages
sent to and from this address for the purposes of investigating or detecting
any unauthorised use of its system and ensuring its effective operation.
Harlequin Valet Ltd Registered Office: 195 Galmington Road, Taunton,
Somerset, TA1 4SS, is a commercial and retail laundry business.
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
=3D=3D=A0
Morning James,
The oil has most likely leaked past the seal on the injector stem, possibly from a leaky rocker cover gasket in the past. Don't worry about it too much, just make sure you replace the seals - RVS don't normally supply them ;-)
Julian
Email: [Email address removed]
Mobile:=A0+44 (0)7971 540 362
