Andrew Prince
- Feb 23, 2010
I presume I have some kind of electrical gremlin. Symptom is my handbrake light comes on occasionally on my 80 - the handbrake is definitely not on (it only gets used at MOT time anyway) and the handbrake is working ok. When I drive off the handbrake light comes on but it goes off when stopped or in neutral. It usually goes off after 15 mins of driving but sometimes it just stays on...
Any ideas before I go trying to trace wires? I'm assuming that there's a sensor/switch on the handbrake to switch on the light when the handbrake is engaged and there may be a bad/dirty contact here? Curious that putting it in gear seems to set the light on but the shifter is near the handbrake lever after all, hence my theory of a wiring/contact issue.
I planned to get underneath today and have a butchers but the wet ground put me off
Cheers,
Cheers,
