Steve-O
- Nov 24, 2011
Well my kit arrived yesterday evening from those nice people at West Coast
. A local garage was going to do the install for me at what seemed a reasonable price, I took the car round to him this morning and I was a bit disappointed that the original estimate had nearly tripled and was in danger of quadrupling too. He also wasn't confident in having it ready until end of next week
. Needless to say I left in search for local alternatives and even a local so called 4x4 specialist was reluctant and in the end refused to touch it (even without looking at it)
. Well I considered taking it to Paul at West Coast to get it done there but unfortunately my work schedule wont allow this for quite a while. So plan "B" it is.... DIY.
Well it is time I got familiar with my 1999 Cruiser complete with all its well rusted nuts and bolts and see if I can work a wonder.
There seemed to be much shaking of heads and scratching of chins over the torsion bars so I thought I'll have a go at one of those first.
I drained what was left of the AHC suspension fluid from the accumulator bleed nipple which obligingly opened without to much sweat.
I then removed the old AHC pump and reservoir and chopped the pipework ( I would not be using the AHC so why not?).
I then jacked up the front RH side of the car and removed the wheel, I placed the wheel + piece of thick wood under the car below the front cross member and jack stands under the chassis.
The torsion bar ends looked as though they would give me hassle but actually no... it was all fairly straight forward. After spraying all the bolts liberally with WD40 I loosened the bolts and started to unwind the arm adjuster, it did tighten up in places but it was easy enough with the aid of an old torque wrench. I found that taking the adjuster down so that the tip of the bolt thread was nearly flush with the top surface of the semi-cylindrical nut was enough to take all the tension out of the torsion bar.
I marked the splines and carriers with a red paint stick so that I could see how it should all fit together and then I prayed that the carrier and arm would come away from the splines....they did with just minimal help from a hammer
I stopped, patted myself on the back and thought the worst is over, this ain't so bad.
I then install my nice thicker dia. torsion bar, I sprayed the splines with a coating of silicone grease just in case I had to re-index the bar and carriers.
At this point I needed some confirmation on the best starting point for assembly, I presumed that with the OE shocker still in place and the wishbones at full drop that if I just aligned the new torsion bar in the adjustable arm with neutral twist and my adjuster bolt as I left it, that this would be right for a standard lift...A quick call to Paul confirmed it.....but he warned me that actually the torsion bars are the easy part of the install
Next the front shocker.
I placed a jack under the lower wishbone and loosened the nut and bolt holding the lower mounting of the shocker (little struggle more WD40).
Then the top mount. Remove a couple of plastic fasteners and fold the splash guard back, I place an old rag under the flexi pipe union near the front chassis member and cut just below it (this will leak out more hydraulic fluid) and then remove the 2 12mm bolts that secure the union to the top of the shocker. Once the union is removed I try to undo the 19mm nut on the top of the shocker.....it isn't budging-no matter what!! Time for the angle grinder....10 mins later and I win.
Whilst I have a chance I remove the old AHC sensor and give all the rusty parts a bit of a clean up and a liberal painting with black goo.
The new front shocker went in without incident.
I put all the bits and bobs back, tighten all the nuts and bolts and I marked the adjuster bolt and the torsion bar adjuster and gave the bolt 10 complete turns for starters.
I refitted the wheel and lowered the car to the ground.
Fantastic...the right hand front seems just right.
I'll have to relearn getting in and out of the car now it's a good 50mm higher than it was
This made me confident enough to tackle the rear.
After having a good look at the top shocker mounts I decided that it would be much easier if I could get at tops through the car.
After a bit of measuring I made the holes with a 50mm hole saw very similar to the plugged holes already in the floor which seem to be the anchor points for the body to the chassis.
This little trick must have saved me a load of time and sweat, the 12mm bolts securing the hydraulic unions to the top of the shockers loosened and came off (place drip trays under the areas where the fluid will drip).
The 19mm nuts on the top of the shockers are extremely well seized and how on earth anyone gets them off from under the vehicle is beyond me.
I found that a good sharp drill bit just about the dia of the shocker spindle made it much easier to drill out the spindle and the AHC spindles have a ready made pilot hole after all. The bits on the shocker tops came off easy after this.
My next job is to jack the back of the car and get at the lower shocker bolts. Now these look particularly well seized but I haven't been able to get to them yet.
Unfortunately one of my rear wheel locking nuts is so tightly on that it has bust the key and the holes in the locking nut don't look good either
It's getting dark too, I've had enough and will tackle the rest later.....more WD40 on lower shocker bolts
.....I do hope!!!
To be continued....
To be continued....
