HDFT INJECTION PUMP
Linwood Hardy
philippines
I have removed all visible bolts and nuts from the pump it moved about about 2-3 MM and stops from all research I can't see anything still holding it from coming off. is their something under the timing gear cover holding it? the tapered drive and keyway I have even tried a puller but don't know how much torque to put on it. What am I missing ? from still holding from it's removal. Any help from someone here THANKS
