HDJ 80 Helical springs
Angelo.
This isn't a mileage specific item to change, depends on use of the car. Basically change them when they are sagged or broken, other than that leave them alone.
I'm sure someone will have ready to hand the factory spec for ride height which should tell you if they are sagging or not.
That is I am assuming you are talking about the suspension coil springs.
Andy
many thanks of your valuable suggestions.
I referred to suspension coil spring.
Regards.
Angelo
