HDJ81V Help !
StarCruiser
Well done Vince! Looks like you’ve got to the bottom of things. As Iwan said, you’ve got two lovely cruisers there. :thumbup:
vsjabbal
united_states
Thank you !
Made another blunder:
- Driver side + - terminals touched accidentally while other battery was still connected. There was a small spark. This happened when I was putting everything back after installing the alternator.
Problem:
- The fan in the car is not blowing, the climate control console has lights and responds to button pushes just fine. No airflow on turning up the fan speed.
- A/C is also not engaging, I can't hear the compressor click.
What I've done:
- All fuses inside are ok. Outside fuses are also ok, none of them were blown.
Any thoughts?
