guyc
- Mar 29, 2016
This morning I rented a two poster ramp at my local garage and replaced the front brake pads, lubricated the prop shaft, rotated the wheels around and sprayed some Lanoguard on.
The wheels, which are the standard 20" alloys with Dunlop Grandtrek tyres are bloody heavy. I'm sure on my 80, although I'm embarassed to say it's so long that I can't remember, you can lift the wheel so it rests on the hub. You can then rotate the wheel until the holes align with the studs and push the wheel on. With the 200, the first thing that engages is the wheel stud so you have to align the wheel and the hub perfectly otherwise it doesn't fit.
Can anyone recommend a wheel lifting device as getting the wheels back on was hard work.
The forward end of the rear prop shaft has a guard on it which you need to remove to get to the grease nipple and one of the others needed a needle nose gun so it was a bit more of a faff than it could have been.
Renting a ramp, which was £50 for four hours worked well and definitely I'll do the same thing when it comes to service time.
