whereisgibson
- Dec 11, 2010
The 4.2 has gone through two AC belts recently. After a bit of googling, I've turned my attention to the two belts coming from the crank and I'd like to know if what I'm seeing is normal.
The two belts run nice and smooth on idle, but manually adjusting the throttle gives them a bit of a vibration, around 1.5cm in total, which is how far they can be finger pushed when not moving. Is it normal for them to vibrate on throttle, or should they be rock steady regardless of revs? I'd appreciate if someone could pop the bonnet and have a quick check on a healthy 80
Thanks!!
Martin
Thanks!!
Martin
