Hi from 200 Series owner with a problem with the reversing camera and parking beepers
RobMit
australia
Hi everyone. I am delighted to join the forum and get to know you better. I currently own a 2014 200 Series Sahara which I have owned since new. This is my 5th Landcruiser having purchased my first (an 80 series) in 1993. I also have a 1998 GXL 100 series manual for heavier 4x4 work. The cameras (front and rear) and beepers have recently stopped working on the 200 series (just after I hired a trailer to move some gear). I suspect there is a fuse gone but I cannot identify which fuse controls the cameras and beepers. I have checked a number of them but so far with no luck. Does anyone have any idea or had a similar issue?
hi, there to all members !!
my 2013 200 series has the same problem the reverse camera and parking sensors have just stopped working ??
does anybody out there know what the problem might be down to ??
and most importantly how to cure this issue !!
any info would be much appreciated
kindest regards (the cruiser king)
07935 110105 anytime
Found the below site with the fuse box diagram for 200. I am not able to understand which one might relate to this system. Worth checking if its helpful
i had this issue and watched a reset video for a camry and i tried this on my 200 series and found tht although i didnt get the settings screen come up but it did fix my cameras , i turned the lights on three times while holding the audio button in and car running in park, i then tried this in reverse and found they started working go figure
