- Mar 29, 2010
need some advice on what to look look for or at???.I have just replaced the two batteries on the car as they had given up after 7 years or so,since ive done that the idle speed has risen to nearly 1000rpm (like when you put the a/c on)being an auto this makes the car want to pull away.The a/c is all still working as normal but the idle remains high if the a/c is on or off????.all the rods on the pump appear to be moving correctly,had a good look round under the bonnet but cant see anything obvious out of place.
cheers gary
cheers gary
