How do I remove the washer jets from the bonnet?
Lorin
Do I need to remove the sound proofing under the bonnet to get the jets out or are they removable from the top?
Depends how much you value the paintwork. They are clipped in and you can if lucky just pull from the top - depends how tight the clips are. You can get away with just dropping the rear of the fire blanket - yes it is a fire blanket not sound proofing. Make sure that it clips up again properly though as the idea of it is with an underbonnet fire the clips melt and allow it to drop on top of the engine and starve it of air - never thought it would be much good for that being as there is quite a big air source coming from the bottom of the engine but apparently it does work.
