warrenpfo
- Jul 21, 2010
Off to view a 100 on Sat that looks clean but you never know until you have had a good look.
I wondered how far is too far when viewing a cruiser.
Should I be undoing the diff fill plugs to check the quality of the oil even if I am going to replace it as it could give you an indication if water has made it in which then means seals would need doing. Do you jack each of the front wheel us to check for bearing play, how about removing the rear light cluster to check for cossosian in the rear panel from water which can get in through the rubber grommets under that get punctured when a tow bar is fitted.
Can I plug my fault code reader in to check for faults or if you dont have one short the approprite pins and how does one get around the "you cant drive the car as you are not insured" problem if it comes up as for me no drive no buy but you would be supprised how many people have told me I am not insured so cant drive but they are happy to take me for a drive.
Lastly does anyone have any good negotiation tips for this http://www.autotrader.co.uk/used-cars/t ... ?logcode=p
I know it has a full service history and has been inthe same family since new. There are no back seats so can use that to get a few pounds off but was hoping to get it for closer to £18. I am prepared to walk away but having had a look around it does seem a good price for the year and age.
Still a crap load of money though.
