notsodusty
- Aug 28, 2017
Hi Peeps , lookin fa some thoughts and suggestions with these issues ,
1/ few weeks ago idle rpm's started to fluctuate from normal always sat at 700 then started to rise to 800/900 , go for a run stop, turn it on again and its sitting on 700 again and we start the same process over again .
2/ Cruise control has started to play up , can turn it on BUT it more often dan not won't cancel when you pull the lever forward .................... not appy
3/Go for a run start in Drive and you hear it kickdown when it should .................... then you start to go up a hill and push down on the peddle and it does nothin won't kickdown just gradually picks up speed but no kickdown .............
Arrrrrrrrrrrrrrrr , pullover and put it into Low , drive off push into 2nd then into drive and it go's back to normal and may not do it till the next day or it could do it 10 minutes later
So any body got some ideas fa dis wacko behavior, be real glad fa any input .
nealy forgot the vehicle is a 2001 fzj105 auto 4 speed petrol . 190,000 ks on da clock
