Intercooling a 1HD-T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, talk with Maarten @ AAI. He will give you all the information and
help you need. His kits are considered to be the best engineered
products on the market.
Reagards Gareth Jones.
Hi Lio,
Usually the vertical strut is removed to fit the intercooler, inless it
is a thin one that can be slipped behind it.
I have a couple of pics of various Intercooler installs, I'll send them
to you off list.
As Gareth mentioned I would buy one of their kits, and work on the
basis of re-locating the auto box oil cooler - I have seen these
positioned between the chassis rails just behind the radiator.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
Gareth Jones a ?crit :
I've worked on an AAI interccoled HD-FT and the thing is very well
engineered to fit the stock intake and EGR piping indeed. The HD-T may
be a bit easier to work on, so that a DIY may be worth the time and hassle ?
