Hi Steve,
I think the dealer is using the wrong terminology, he says rack but means
box - the 80 series doesn't have a rack it has a box (you do have an 80
series not a 100 series?). You probably don't need to worry about the
difference at this stage, if he is replacing the box that will hopefully
solve it.
When you say 'with the ignition on' do you mean with the engine running or
do you mean with the engine off but the key switched to the running
position?
If it's the former then that would make sense - the power steering works on
hydraulic pressure created by an engine driven pump.
If you mean engine off but ignition on then that's a lot more confusing; you
do have speed sensitive power steering, so there is a solenoid valve in your
system which probably could only be activated with the ignition on. How this
would produce the effect you're getting without the hydraulic pressure being
applied I don't know.
I could see the steering damper binding if it got bent, but I can't imagine
any way it could actively turn your wheels - it is just a piston with holes
in it being pushed through a tube of hydraulic fluid, also it is completely
independent of the engine.
Best of luck,
Toby
___________________________________________________________
Copy addresses and emails from any email account to Yahoo! Mail - quick, easy and free. http://uk.docs.yahoo.com/trueswitch2.html
solve it.
position?
Best of luck,
Toby
