Is the 120 the same as lexus gx450
tony rodaway
Hello guys
I have just replace my rear height sensors for my rear suspension.
My problem is it has gone into safe mode apparently and has gone to its highest setting.
My dash light indicator for my height control is stuck in neutral.
I have watched a clip on YouTube we're the guy has a lexus gx450 with the same problem.
He appears to stick a wire in his obd2 plug socket and joined the 4th hole from the left on the top line to the 5 hole on the bottom line with a single wire.
He pressed the break on and off with the ignition on and then ignition off.
Removes the wire and turned ignition on and was reset.
Is this the same reset sequence for the 120.
Don't know for certain but I bet its the same as I think they're basically the same cars.
I had to do something very similar (dont remember the exact pins) to reset the immobiliser when I changed the ECU - I remember the dashboard lighting up like that.
Will do some more research before I try it but as you say it's the same car just more features on it.
just checked my notes and I shorted the same pins - 4 and 13 to reset my immobiliser! So I reckon you are safe!
Thanks karl your a star and will keep my notes updated to help others with the same problem. :clap::text-bravo:
