KZJ78 for sale Dorset UK £8000 ONO
graysworld
MOT 30 April 2022 322420 Km this will increase as it is my daily driver
Good points
Cambelt and auxiliary belts fitted. Almost new tyres. Rebuilt front brake callipers. New front discs and Pads. New flexi brake pipes. Manual front hub conversion. New hub bearings. New swivel bearings and all seals. Transfer case rebuilt with Terrain Tamer kit. Prop shaft universal joints replaced. Rust to bodywork cut out and replaced. Fuel tank removed and all brackets and bash plate repainted. Fuel filler pipe replaced. rear flexi fuel hoses replaced. Underside cleaned, rust treated and protected with Dinitrol. Cavities treated with Dinitrol. All wheel arch extensions removed, and all brackets treated for rust and resprayed. Repairs made to fibreglass wheel arches and mud flaps. Rear bumper removed and rust treated and resprayed all brackets treated and resprayed. Side steps removed and all brackets rust treated and repainted. All bracketry has had rust removed with electrolysis. Track rod rubbers replaced. Mot advisory work (drop link rubbers) completed. New rear pioneer speakers fitted. Comes with rear discs and pads (bought but not required). Air con works. LED Interior lights. Old Man Emu suspension (repainted black). Air conditioning works.
Bad bits.
Small hole in bodywork at top corner of windscreen. The windscreen has a small crack but not an MOT failure. I was going to put a new windscreen in and fix body work at the same time. It has a waterproof patch for now. A few small dents here and there. The roof gutter has been bent with a roof rack by a previous owner. Paint work around area is poor. Arial has been snapped off and a temporary repair made. Works fine.
Bottom of one rear door, sill repair and rear quarter panel repair painted black. 4wd indicator light not working. Clear coat pealing on rear wheel arch extensions.
Feel free to call me and discuss further 07969975377 I can email more photos
Graeme
  • 20211009_144316.mp4
    20211009_144316.mp4
    4.1 MB
Just listed on ebay after having starting problems I have had the ECU Repaired and all is fine now.
Item number: 115084163156
Graeme
Hi there just wondering if your kzj78 is still available for sale
