AndrewCorser
- Sep 28, 2013
Thanks!You mention the brakes pulling all over the place, is this the ABS doing it or do you have a sticking caliper as Shayne possibly had before he got them rebuild.
Unless you already have done so, I would check that the actual sensors are not at fault either
I have had all the callipers replaced, so it shouldn't be that (unless the disks would affect it? They were in reasonable condition).
On the wheel sensors, I got a replacement front one, and we tried it on both sides, but got the same fault codes, suggesting it isn't the front sensors. We also checked the cleanliness and condition of the toothed sensor rotors on the front. At the back we have only checked one of the sensors...but the symptom is the juddering ABS feeling through the brake pedal at 10 mph, AND pulling (one way and then the other) which suggests to me it is related to the front sensing rather than the rear sensors. I suppose I could replace both front sensors with new ones since I have now found those on-line (the replacement one was from Karl and I'm not sure if it was new).
Thank you everyone for your support on this issue! It is really frustrating: at 71, I want this special 30+ year old vehicle to see me through another 30 years, and the only outstanding issue is this ABS!
