- Apr 10, 2016
When the engine is running the left hand 2 pipes are leaking diesel at the junction with the block.
What to do about it?
Are there seals in there that can be changed?
Thats grest, thanks Firewout. So a rubber o ring and a copper gasket in each delivery valve. Looks like i will need a multipoint socket too to undo them with like 60 points or is there a special tool?yes there is a gasket
I think looking at your pic that they will undo with the larger hexagon once the locking plates are removed, and the fine teeth around the outside are purely for the locking plates to hold them by.Thats grest, thanks Firewout. So a rubber o ring and a copper gasket in each delivery valve. Looks like i will need a multipoint socket too to undo them with like 60 points or is there a special tool?
Thanks for your help
