- Mar 1, 2010
Folks,
I have a small rust patch next to the drain plug on the sump of my 2001 FDJ-100 (Auto). There is a small oil drip when the motor is warm.
I'd like to quickly remove the sump and weld in a patch.
I have the under-trays off and removing the sump looks like a tricky job. So:
1. Is a leaking sump an MOT failure (it wasn't last year but its a bit worse now)??
2. Can I remove the sump without dropping the front diff & drive shafts ??
I can see that the sump bash guard has to come off and the cross-member that holds the suspension together (along with stabilising the N/S axle tube) can be removed.
I'm hoping that I can do this in a day or so as its my only available car at present and I must complete the work on the other two in the garage before starting on another major task.
All being well I can get it MOT'd now and fix the sump later in the Summer.
Advice please
Bob.
Advice please
Bob.
