Light stock
IRLGW
My full beam hasn't been working for a while now and I'm pretty sure its the switch ion the bottom of the stock. Does anyone know if these are a generic toyota part from the mid ninties or if they are specific to the landcruiser. I have an MOT on wed so either I hook it up to a switch or swap it with the one out of my mums rav4 :shhh:
Are you sure it is not the relay under the bonnet? As mine plays sometimes.
Thanks Paul
Had not checked the relay as when I flick the stock away for full beam it turns all the lights off but then I could get it to work sometimes by flicking the stock towards me really fast. Will check the relay now that you mention it.
I would suggest checking the relays under the bonnet as mine were giving trouble, would not switch off high beam to start with and then would not turn lights on unless I gave the relay a tap.
There are two relays, one for low and one for high.
It wasn't the STALK, it was the REEL A.......contact were worn so bent them out a bit further and its as good as new once again
