Steveindar
- Nov 17, 2014
Hi Guys,
A recent trip to the capital city and back ended up with the last 400 km's running after dark. Strange stuff started happening to the lighting circuits. First the speedo lights all went out with only the gear indicator light and bright beam still working. At the same time the side/parking lights went dead and so did all the rear running lights and licence plate light. This lack of power affected the fog lamps too. Those of you who have travelled on the dark continent will know that making it any darker by running without sufficient light is more than scary.
Story doesn't end there though. The brights would also all of a sudden fail leaving me with absolutely no illumination. To recover this flicking the stalk to low (which would work) and then bright would get the brights to work again. Several really panicky moments but we got home with no rear lighting and prodigious low/bright flicking to keep some light going forward.
This morning everything works and is back to normal, and try as I might without waiting till dark I'm unable to replicate last nights issue.
I'm trying to make sense of the vast amount of electrical drawings, but I figure there is some clever dude here who can point me straight at whatever power source seems to be failing.
Swambo has mentioned this happening before but that was just tootling around between farms and shortish distances. I rarely drive the car so was sceptical until last night.
Is this a main relay issue, or the stalk switch? Where to look as it affects all the lighting?
