I think it took longer to re-size the photos than to actually change the clutch! That said I took some extra time to clean around the tunnel and remove and dirt or surface rust from the surrounding chassis and brake pipes and repaint with a smooth finish Metal paint (Triflow).Its a fairly simple jon and the FSM does pretty good except for two things.
1). Removing the gear levers - it may be somewhere else but not under the clutch section!
2). If you were to go step by step it would suggest removing the box then splitting the transfer box
I would suggest likemany others have done to remove the transfer box first -even with a two post lift, two people and a transmission jack it wasn't so easy.
3). I left the front stabilizer bar in to help support the engine/gearbox while we removed the top two bolts in the bell-housing. This worked ok but I should have removed before separating the box to make life a little easier.
The clutch went completely as I was holding out for a delivery from OZ with a relative, so went for a cheap solution from Milners costing around £175 inc VAT & Delivery. It seems to be ok and although it has two more springs than the Toyota clutch that came out it doesn't feel just as tight on the pedal. The OEM one that I removed was from Aisan and Toyota stamped.
Lots of photos so hopefully they will upload ok and in the right order.
![Naughty :eusa-naughty: :eusa-naughty:](/custom/images/smilies/pack2/eusa/naughty.gif)
