Animal Mother
- Sep 27, 2016
I went with a Varta G7 starter (830CCA) battery, a Rolls 12FS105 accessory battery (105Ah) and a T-Max split charge system.
Starter battery
Accessory battery
Controller mounted on velcro.
SHowing voltages
T-Max relay mounted on steel bar (coated in heatshrink), mounted on fan cowl.
Using original battery cable and original cable management clips/duct.
Cabling uses original large grommet in firewall (driver side). You can see me accessory power cable coiled up waiting to be plumbed into the battery at a later date.
When I find one, all of this will be covered in a nice neat plastic box.
It was a full day's work, but I took my time with cable routing, soldering connectors, heatshrinking, good cable routing, etc.
Starter battery
Accessory battery
SHowing voltages
