Nordkapp => driving in extrem cold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 Lio,
No idea at the moment - I'll look into it ;-)
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
Absolutely. No probs in -35 C. We drive in even colder weather. As long as we can keep the fuel liquid.
(My old Corona Mk-II would even keep T-shirt warm in - 30)
Heard that Arctic Trucks broke the rear springs when they took to LCs to the south pole, but there it gets even colder.
-- Ugo Hu, Oslo, Norway
HDJ100, Auto, AHC, 2001; ex HZJ80
On Fri, 17 Aug 2007 09:03:42 +0200, HEBERT Lionel <[Email address removed]> wrote:
d.
ld
Hi Ugo
how is the warm in your LC100?
Sa long as I know D4D is not so effective to warm the car...
cheers
Lubo
The 100 I haven't taken to the north yet. Moved from there in 1992.
Around here it doesn't get colder than -15 at the worst, maybe -20 a bit
inland. No probs with that so far. The 100 diesel has, btw, a power
heater, some kind of viscous friction heater that helps the engine heating
up. It generates only 1400 watts of heat, + it also increases the idle
rev. Not much, but it helps. I know that diesels might get cold while
idling because of their high efficiency.
My 100 "grew up" in temps of +20 to +40-something all year. That was more
of a problem, with 40 C outside, + the sun baking, and without a 2nd AC
for the rear. But not too bad. Engine always stayed cool as a cucumber.
On Fri, 17 Aug 2007 14:54:31 +0200, Lubo <[Email address removed]> wrote:
So it seems like you don't need auxiliary heating(sort of 'webasto') for the
100 series?
cheers
lubo
Maybe not as long as the engine is running, but it would be very helpful
for heating it up before starting, if you don't have an electric block
heater connected to the mains.
On Sat, 18 Aug 2007 02:32:46 +0200, Lubo <[Email address removed]> wrote:
