OME - how much to lift ?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=
Hi Lio,
I'm aware of consequences of the lift - on my kzj95 I have a OME lift
with medium stiffness and it performs really well. But in the begging I
had some stability problems (nothing serious ....) which were solved
using wheel spacers.
But each car behaves differently and my opinion was that hdj80 should
allow more freedom regarding lift since its wheelbase is wider,
different construction etc...
The plan is to use primarily for for over landing which is in my
experience 60% tarmac - 40% off-road in terms of distance . I'm not
planning to put very stiff springs since I'm usually carrying stuff for
two people and additional fuel (I'm thinking about additional fuel tank
of 160 liters which will be used only occasionally).
regards,
Tomaz
