On Board Air - What is needed?
Bat21
morocco
I have a Paddocks compressor and am about to order some Air Line, 'T' and 'Y' pieces.
I'm not fussed about including a tank in the system, just want to hard wire the compressor in and have easily accessible air supply sockets.
What do I need to connect the air line to the compressor? Also I'm planning on having either an outlet at each corner or on on each bumper, what do I need at those ends for the inflator to attach to?
I would keep it simple. Mount it inside the cabin if possible. This will keep it free of dirt and moisture. Forget plumbing in a load of pipes/hoses. Use the spiral hose supplied. This should be long enough to reach each wheel.
Roger
