Ooze @ steering knuckle
  • Start date Start date
Hi Toby
Thanks for the response.
I was just curious about the ratios in relation to what difference it would
make as you say in the second part of your answer.
I heard this before but like most things over time it slips from memory
untill you mentioned it.
My stock tyres were only 265/70/15 so about 29.5 inches I think.
I now run 285/75/16 about 33 inches.
Its also auto which changes gear depending on revs/ speed/ and labour on the
engine, put simply of course.
So if I put the old wheels back on would it change gear at a lower speed
and would the ratios of the diffs be better and less strained and the
braking effiency would be increased and id get better mileage aswell..
Just curious as I would not change back I think the old ones looked way too
small and out of place for such a machine as the 80.
The colorado is just stoke with road tyres and is a good bit lower than the
80 but the steering is a lot heavier and of course its manual which is
different, but it does get to a higher speed quicker.
Its a lot quieter than the 80, no roar from the engine and when it is
switched off the engine dies very smothly unlike the 80 which gives a last
jolt of life.
cheers
john 92 hdj80 1hdt
SNIP
The different stock ratios that came on the European 80s can be quite useful
if you have, for instance, replaced the 31" tyres on your '90 to '92 manual
80 (3.7 ratio diffs) with 35"s. Just fit a pair of 4.1 ratio diffs from an
automatic model and you're roughly back to stock gearing. Of course finding
them is another matter. Ring and pinion sets (the ring and pinion define the
ratio) are available separately, but they aren't exactly cheap (often
similar price to second hand diffs) and then you need to find someone who
knows what they are doing to fit them - this is not a job for your Yaris
man.
If you have put taller tyres on your 80 this might explain why the Colorado
seemed more responsive. That or your iffy fuel pump ;-)
Chas wrote...
I've managed to source an 87K mile front axle from a '95 cruiser, the
question is, will it fit OK in a '94 cruiser?
SNIP
Chas the answer will be on the bulkhead spec plates of both vehicles
in the second set of digits after
'Trans/Axle'.
In case you don't have a copy of the famous TLC FAQ, here is the
definitive answer to all the ratios.
(And JB, if the ratios are different between axles, then you will get
wind-up and transmission failure very quickly as the wheels at each
end of the truck will be revolving at different speeds).
==========Axle codes are never located on the axle housings themselves. In
trucks manufacturered after 1976, the axle codes are located on the
build plate which can be found inside the engine compartment. The
pinion (and sometimes the ring gear have the tooth counts (from which
the ratio can be calculated) stamped into them.
Example: K 08 2
^ ^^ ^-2 spider gears
| ++---4.11 ring/pinion ratio
+------9.5" ring gear
First digit: ring gear size
G 8"
J 9.25"
K 9.5"
Second, third digits: ring/pinion gear ratio
(These numbers apply to ALL Toyota vehicles--known Land Cruiser ratios are
indicated)
01 3.30
02 3.36
03 3.545
04 3.556
05 3.70 HD Cruiser, Aftermarket HD Cruiser
06 3.889
07 3.90 HD Cruiser
08 4.111 HD Cruiser, Aftermarket HD Cruiser
09 4.222
10 4.375
11 4.444
12 4.625
13 4.79
14 4.875
15 5.125
16 5.286
17 5.60
18 5.714
19 5.833
20 6.167
21 6.667
22 6.78
23 6.833
24 7.64
25 4.556 LD Cruiser, Aftermarket HD Cruiser
26 5.571
27 3.364
28 4.30 LD Cruiser
29 4.10
30 3.727
31 3.909
32 6.591 or 5.583
33 7.503 or 5.583
34 6.781 or 4.786
35 7.636 or 5.60
36 4.778
37 3.583
38 3.417
4.88 Aftermarket HD Cruiser
Fourth digit: no of spiders, ltd slip/locker
Code spiders
2 2 open
3 2 LS
4 4 Locking Diff
5 4 LS
========================Cheers
Jon
Tring,Herts
'92 HZJ80 ex UN Bosnia surplus - TRANS/AXLE - H150F / K292
