Total guess, is it some sort of idle up so if you're hauling on the steering at slow speeds the engine will get a bit of extra fuel? No idea about the pipesfrank rabbets said:There is a valve? fitted onto the top banjo fitting on the ps pump. It has 2 pipes, one going to the vacuum pump and one to the rest of the vacuum circuit. Does anyone know what it is for? Also does it matter which way the pipes go on?
