[?? Probable Spam] spots
John
as I understood from Clive if you use 100W bulb you don't have to upgrade-am I right?
cheers
Lubo
----- Original Message -----
To: [Email address removed]
Sent: Monday, October 29, 2007 12:14 AM
Subject: [?? Probable Spam] Re: [ELCO] spots
Hi Guys
Thanks for the input.
I cant spend =A3300 for spots as I would only use the spots when high beam is on.
I like the idea of the spots with a low /high beam which seems to sadisfy the need for more light at low beam.
High beam on the 80 is fine when you concider there are four lights.
I did have to replace the main relay for the lights about two years ago , but I think this was due to age.
They are expensive and I said after that I would carry a spare but like some of the things we say we will do I forgot.
Is it possible to just fit LED bulbs because if they use less power then the power that is lost through the OME wiring will not matter, is that correct.
Ill check the stronger 100 watt bulbs and the 30/50% extra bulbs and see which is best and hope my relay stays working.
Then there is the LED bulbs if I can get ones to suit.
After that there is the wiring upgrade and or spots.
john 92HDJ 80 1HDT
OK Clive
at the end of the day do I(we) have to upgrade the harness or not?!?!
rgrds
Lubo
Relax Benoit :)
it will be that winter!!!take a glass of red wine and be patient...
cheers
Lubo
To: <[Email address removed]>
Sent: Wednesday, October 31, 2007 1:07 PM
