- Feb 24, 2010
I was hunting for something else but came across this. It says you can read off the codes on the D4D but not sure if that is the latter model (>06 which is OBDII apparently) or all.
Compliments of Prado Point:
1) Make sure the ignition is OFF, throttle closed, Aircon OFF and if it’s automatic have it in P.
2) Turn the ignition ON but don’t crank or start the engine.
3) Put the jumper wire across the connector pins. (pin 4 and pin 13)
4) Read codes displayed via the engine check light.
5) Disconnect the wire when finished extracting codes and turn the ignition off.
Images on original post to help.
