StanM
- Feb 14, 2017
Hi all, I'm trying to resolve an issue with my rear wipers on my YM2000 Land cruiser, 4.2 Diesel, Standard with Barn doors.
The issue I have is that the RH rear wiper isn't working but the LH rear and washers are working fine.
I have checked for power at the connector and found no power to the motor (the motor is OK, I swapped it to the other side and it works fine). I have checked all the fuses, wiring and connectors and they all appear to be OK with no obvious damage/faults that I could find. There is continuity from to the junction box to the motor. I have tested in accordance with the workshop manual and it says that the power for the RH side is supplied via the Controller and Junction Instruments part no: 82791-60021 which I have since replaced without success and cost $100. Am I missing something ? any ideas wold be appreciated.
YM2000 Land cruiser 4X4, 4.2 Diesel, Standard (barn doors)
Vin/Frame: JT711PJA507016991
Build: 2000/03
Model code: HZJ105R-GCMRSQ
Engine: 1HZ (4200CC DIESEL)
Grade: STD (STANDARD TYPE)
Trans: MTM (MANUAL TRANSMISSION)
Gear shift type: 5F (MTM, 5-SPEED FLOOR SHIFT)
Back door: SOB (SWING OUT BACK DOORs)
Color code: 056
Trim code: LK11
Build: 2000/03
Color code: 056
Trim code: LK11
