SteveS
- Jan 12, 2013
The previous owner of my truck removed the wire loom and solenoid that connects the air heating matrix to the battery when air is pre-heated on cold morning (similar function to glow plugs). The attached two sketches give the part numbers and approximate locations. The solenoid looks to be mounted behind the air filter box, and the matrix is on the air intake.
Could somebody please take a photo of the wire loom route so that I can re-instate it in its original position, particularly as it bridges the gap between the chassis/bay and the engine as this is where the rocking action of the engine is most likely to be critical to the loom reliability. The loom number is 82124-60080, the solenoid is 28610-17090
Even though I have split the batteries, I see no reason why the heater matrix cannot be connected back to one of the batteries (in this case it will be the leisure battery) - if anyone has any thoughts on that then I would be happy to receive them
