I have always used the Repsol range of oils here in Spain, both for my own vehicles and customers as well, there has never been an issue.
On the 20th of February this year I changed the oil using my typical technique, engine hot, oil and filter out, new filter and refill with fully synthetic, fast idle for 10 - 15 minutes, drain again and change filter again, finally new 10/40 mineral oil......job done or so I thought.
There was considerable mud around the engine bay as there have been a few wading sessions getting to my house recently, so I drove down the car wash and jetted the engine off.....yes there is a jet was in the workshop....don't ask.
On the way back I braked for the rambla I have to cross to get to my house and the oil pressure light started flashing and the warning buzzer started sounding. I dipped the clutch and shut off the engine and guessed I had a blown oil filter, or worse left the bloody sump plug loose! Opened up the bonnet and there were no leaks, there was the correct amount of oil in the sump so I finished the last hundred yards drive home.
With a master gauge it showed the pressure being down about 7...ish psi? Given my oil pressure switch is a master version it showed the pressure is sufficient but why the change? My oil pressure switch set circa 20 psi. After changing the oil filter again, checked connections, blah blah, I noticed the oil I had been sent was the Repsol 10/40 but now there is a label saying 'synthetic blend'. In theory this should not be an issue I mean a 10/40 is a 10/40 right? Well I will qualify that and say 'well respected brands' should be the same. Anyway, being allowed out for the first weekend in what feels like years I hit some local trails and got the engine up to proper temps as the 80 is really well and truly ready to go, roof rack and all the usual camping goodies the engine getting a good workout, sure enough the buzzer and light showed again at idle. I spent some time with the supplier this morning and it was agreed to try a different brand oil, the mineral version Repsol is no longer available. So another oil filter change and a refill with Total 10/40, this also being labelled a 10/40 synthetic blend. It does appear to have upped the oil pressure a tad so I will see how it goes.
Amazing how I have three different 10/40 oils and there is such a variance in the viscosity. Just how wide is the test tolerance to grade an oil FFS?
regards
Dave
regards
Dave
