reverse lights
  • Start date Start date
Hi Guys
Does any one know where its possible to get stronger reversing bulbs. I saw some thing some where that you can get bulbs that shine whiter and so give out more light, buy where is the question.
Thanks
John c
92HDJ 80 1HD-T Auto Ireland
If you find the info, please post it here.
You can either look for a higher wattage bulb or fit a 3rd party lamp,
like a fog light to stick on the bumper.
Julian Voelcker
Mobile: 07971 540362
Cirencester, United Kingdom
john
Try http://www.norbsa02.freeuk.com/goffybulbs.htm they sell quartz halogen "Indicator" (that's the PY21W fitting) bulbs. They are 20w, as opposed to 21w for the standard bulb, but they should be brighter. Haven't tried it myself, but I've read elsewhere that they are better.
If you are handy with a soldering iron you could probably bodge a headlight bulb (a small one like a 55w H1 or similar would be easiest) onto a standard bulb base, and glue it in with epoxy resin - I don't think the extra current & heat would matter for the length of time they are used.
Christopher Bell
Devon, UK
1996 1HD-FT
